help a/c is acting funny please help me
rhino_inc on Thu May 06, 2010 1:31 AM User is offline
Year: 2004
Make: chevy
Model: tahoe
Engine Size: 5.3
my a/c is acking funny i put freon in the car and it was cold for two days and i was getting off work and i turn the a/c on and i felt hot air and as i was driving it got a little colder and when i stop is was warm and as i got home i look at and the truck i seen a lot of water coming from under the car where the ac is at before it would be a little bit of water now it alot and i turn the car off and looked for a leak nothing and when i turn the key i can hear lots of water falling on the ground without the car on and the ac was blowing and now i put two more can of freon in its cold now but its just a lot of water falling please help figure this out thank you
metalgod3082 on Thu May 06, 2010 2:03 AM User is offline
Wow that's quite the run-on sentence there. Could be the water pump leaking. Have you looked under the car to see where it's coming from?
HECAT on Thu May 06, 2010 6:05 AM User is offline
Put freon in... cold for 2 days... put 2 more cans in... cold again.
It does not take much to figure out you have a major refrigerant leak that needs to be found and fixed. The water is condensate draining and may have increased simply because of an increase in humidity.
