99 lumina sedan evaporator leak
mektek on Mon May 03, 2010 3:35 PM User is offline
Year: 99
Make: chev
Model: lumina
Engine Size: 3.8
Refrigerant Type: 134
Hi!
I've checked everywhere in the engine bay for a slow leak with both electronic and UV detection and nothing shows. The remaining possibility is the evaporator but I don't see how to access it.
Anybody know how to check it or what parts to remove to get to it?
thanks!
GM Tech on Mon May 03, 2010 5:03 PM User is offline
Number one leak location is compressor shaft seal followed by compressor body o-rings---I haven't seen an evap leak ever on that style W-car-- so are you sure your shaft seal is okay-- I change shaft seals and have never seen a dry one on a V-5 single lip shaft seal application. If you remove your clutch driver- I'll bet the shaft seal is wet and drooling oil- if it is the OEM compressor.
The evaporator change is a dash pull btw.....
mektek on Wed May 05, 2010 3:56 AM User is offline
The Compressor has been completely resealed - tight as a drum :-)
Looks like I'm in for some misery - it's 95 degrees here in FL and no fun tearing out the dash. I'll try putting in some r134 and using the electronic sniffer around the vents.
In my pathfinder I was able to remove the blower motor and directly access the core. I guess there's no such shortcut with this one.........
