Seltec TM-15HD drive plate removal
commander115 on Mon April 26, 2010 2:01 PM User is offline
Year: 1995
Make: Ford
Model: F-250
What do I need to remove the drive plate on the Seltec TM-15HD?
Can I pull the pulley and drive plate off together at the same time?
Edited: Mon April 26, 2010 at 2:03 PM by commander115
TRB on Mon April 26, 2010 5:11 PM User is offlineView users profile
Hub and pulley are removed separately. I use a puller designed for these tasks when i need to remove them. You will also need to remove the snap ring before removing the pulley itself.
commander115 on Mon April 26, 2010 6:23 PM User is offline
Can you steer me in the right direction for the puller? The only place in the front of the driveplate to attach anything is the center hole.
TRB on Mon April 26, 2010 6:26 PM User is offlineView users profile
Some hubs will have 3 threaded holes to attach bolts for the puller we use. If they are not there you should be able to remove the center bolt and the hub should slide out if it's not gotten to hot.
commander115 on Mon April 26, 2010 8:09 PM User is offline
I removed the bolt in the center of the driveplate and it will not budge. The center hole is the only hole threaded or not in the front of the hub. Nobody local has a clue. Any more suggestions would be appreciated.
TRB on Mon April 26, 2010 8:58 PM User is offlineView users profile
Post an image of the front of the hub.
commander115 on Tue April 27, 2010 10:48 AM User is offline
O.K.
Edited: Tue April 27, 2010 at 10:58 AM by commander115
TRB on Wed April 28, 2010 9:41 AM User is offlineView users profile
Remove the center bolt and it should pop off . May need to help it along with a couple of screw drivers.
