Evaporator Install Lincoln Mark VII
hjc149 on Thu April 15, 2010 1:15 PM User is offlineView users profile
Year: 1991
Make: Lincoln
Model: Mark VII
Engine Size: 5.0
Refrigerant Type: R-12
I have my evaporator/heater box out of the car and am trying to remove and reinstall the new evap. The shop manual says to cut the box on 3 sides allowing the top to swing open. However, the box the manual shows has 2 tabs that are to be cut and then used to hold the top in place, once the new evap. is in place, with the use of a spring nut and bolt. My box does not have these tabs so I'm not sure how to hold the swung open part to the box. The box itself appears to be glued together, although I'm not sure of this, and for this reason don't want to try and force it open. Has anyone been thru this with a '91 Mark VII that could provide a little guidance?
robs on Thu April 15, 2010 5:12 PM User is offlineView users profile
***REMOVAL***
Remove instrument panel and evaporator case. Remove seal from evaporator core tubes. Drill 3/16" diameter holes in both upright tabs on top of evaporator case (1/4" down from notch in tabs).
Using small saw, cut through center of tabs (and drilled holes) following top seam of evaporator case. Cut along tab side and short sides of seam only. Fold cut-out flap back and remove evaporator core from case.
***INSTALLATION***
Install new seal on evaporator core. Install core and close cut-out cover. Use Caulking Cord (D9AZ-19560-A) to seal cut-out cover. Install lock-nuts and bolts through drilled holes in upright tabs. To complete installation, reverse removal procedure. Evacuate, recharge and leak test A/C system.
hjc149 on Thu April 15, 2010 5:35 PM User is offlineView users profile
Originally posted by: robs
***REMOVAL***
***INSTALLATION***
Thanks, Rob, but as I said, there are no tabs to drill.
hjc149 on Fri April 16, 2010 10:16 AM User is offlineView users profile
I'm wonder if I could rivet 2 metal
tabs onto the box to hold the 2 sections in place where the cut has been made. Is the plastic strong enough to take a rivet without cracking?
Edited: Fri April 16, 2010 at 10:20 AM by hjc149
