AC clutch
lwflyer on Mon April 12, 2010 12:54 AM User is offline
Year: 2001
Make: GMC
Model: Topkick
Engine Size: 8.1
Pressure Low: 90
Pressure High: 0
My AC is not getting cold. I checked my low side reading and it is at 90. My clutch on the compressor is not engaging. I check the wires and I have 13 volts and I also ohm'd the wires and have 3 to 4 ohms so I'm fairly sure the coil is ok.
I'm not sure of what else I can check.
Any suggestions would be greatly appreciated.
GM Tech on Mon April 12, 2010 9:16 AM User is offline
Tap on clutch with hammer handle- see if it pulls in-- if so, your air gap is too wide- it can be narrowed- depending on your compressor brand.
Cussboy on Mon April 12, 2010 9:32 AM User is offline
With engine running and AC switched on, Tap on clutch CAREFULLY with hammer handle- see if it pulls in
lwflyer on Tue April 13, 2010 5:00 PM User is offline
Tried the end of the hammer still no clutch. I tried adding 134a and now read 90psig on the low side and 70psig on the high side.
What else can I try or look for?
mk378 on Tue April 13, 2010 10:48 PM User is offline
Did you measure voltage between the wires at the coil? If not do that, also check that the other wire of the clutch is grounded. You could have power on one wire but no ground.
If you really have battery voltage between the two wires, it should pull in. You can jump it direct to a battery with the engine off then push on the plate with your hand (engine off remember).
lwflyer on Tue April 13, 2010 11:08 PM User is offline
Thank you. I will double check tomorrow. I tested voltage with the two wires and it was 13 volts. I thought I checked the - side to ground but I will check it again.
I also checked the coil ohms and it was around 3.
lwflyer on Wed April 14, 2010 10:26 PM User is offline
Could a blocked orifice cause the low side pressure to be high and the high side pressure to be lower or is it because my clutch is no engaging?
