blend door snafu
mott on Mon March 29, 2010 3:02 PM User is offlineView users profile
Year: 1998
Make: olds
Model: bravada
Engine Size: v-6
Refrigerant Type: r-134
i recently replaced compressor, accumulator., orifice tube, and lines and flushed the system. the problem i have is the blend door cycles back and forth. as soon as it reaches one end of it's travel it reverses. it only takes a few seconds each way resulting in cold/hot/cold/hot etc. whazzup? help me, my wife is mad.
HVargas on Tue March 30, 2010 11:16 AM User is offlineView users profile
As best I could find, the reason it is cycling is because it is trying to search for the right spot to find temperature. There are a couple fixes for this. First, you can move the temperature knob back and forth several times and then start at one temperature and slowly move the knob to each setting. This will sometime's reset it. Otherwise you will have to remove the dash to replace the blend door actuator.
Contact: Arizona Mobile Air
mott on Tue March 30, 2010 2:36 PM User is offlineView users profile
thanks, i'll try that. i did put it on auto and it worked for 1 day.
