Hose Crimp Question
clindahl on Mon February 15, 2010 11:47 AM User is offline
Year: 1994
Make: Ford
Model: Aerostar
Engine Size: 4.0L
Hello fellow A/C Folks!
I need to repair and or replace a flexible hose section in the middle of a metal line on a 1994 Ford Aerostar. The host isn't readily avaiable, I'm sure I can find it if need be, but I enjoy doing things my self, so here goes -
I was looking at the 71550 - Hydra-Krimp (Basic Crimper) for purchase. What style hose ends do I need to replace on the metal tube for the crimp to be successful. From my reading there are two styles, a barb fitting and a beadlock fitting.
From my reading and searching online I need to remove the existing fitting (cut it off with a tubing cutter) and braze back on a new fitting. The tube is steel, and replacement fittings will be steel - depending on which style I need. I will be using barrier hose (standard not reduced wall) for the R134a system.
Thanks for any help you can provide!
TRB on Mon February 15, 2010 12:01 PM User is offlineView users profile
In the last few tables in the link provided are the ends needed to replace a hose section. Size and tubing type is what you need to keep in mind.
Mastercool crimper is a good choice.
