compressor clutch availability
dabunk on Thu January 07, 2010 7:43 AM User is offline
Year: 1990
Make: Ford
Model: E350
Engine Size: 7.3L die
Refrigerant Type: 134A
I need just a compressor clutch assembly for this vehicle and cannot find it on the site. Any help appreciated, system and compressor are perfect, just clutch coil fried from short. Dave
iceman2555 on Thu January 07, 2010 10:30 AM User is offlineView users profile
There are numerous companies that supply this unit. Does your vehicle have the OE FS6 compressor or is equipped with the Sanden unit?
HVargas on Thu January 07, 2010 11:25 AM User is offlineView users profile
Depending on whether it was dealer or factory installed air we have both clutches available. If it has an FS6 (Factory Installed Air) the clutch is, 22-11086. If it has dealer installed air it has an SD709 or SD508 the SD709 clutch part number is 22-10111. The SD508 part number is 22-10106. All of these show running a 12V system so make sure it's 12V not 24V.
Contact: Arizona Mobile Air
