Clutch Plate surface
joeld on Fri November 06, 2009 3:21 PM User is offlineView users profile
Year: 1994
Make: Buick
Model: Lesabre
Engine Size: 3800
Refrigerant Type: 134
What is the proper condition of the friction side of the clutch plate to hub/pulley? Mine has a somewhat thin layer of grease mostly on the hub. Also, should these be smooth with no "rough" ridges?
Vehicle has 62K miles on it, if that matters.
Joel
Chick on Fri November 06, 2009 4:32 PM User is offlineView users profile
Should be smooth, you may have a shaft seal leak, or engine oil dripping on it, but it should be dry...
joeld on Fri November 06, 2009 4:57 PM User is offlineView users profile
Thanks for the reply.
In your opinion is it worth installing a re-man clutch from NAPA? Cost for this is about $100, then I'll have to buy the install tool kit for another $65 to $80.
Joel
Chick on Fri November 06, 2009 5:29 PM User is offlineView users profile
If the front seal is leaking, you would also have to fix that.. I would e-mail the guys at Ackits.com for a price on a reman. They may even have offshore new for that, but I'm not sure... Fixing just the clutch without fixing the problem is a waste of money in my opinion... Hope this helps..
