Manifold Gage set Kit.
grtpumpkin on Tue October 06, 2009 8:37 PM User is offline
Year: 0000
Make:
Where can I purchase the seals and o rings for my manifold gage set? I have not seen them anywhere. Some of the seals look like they are conical shaped? Can you say Specialty Item?
TRB on Wed October 07, 2009 10:41 AM User is offlineView users profile
Different gauge sets use different seals. What brand are you using?
grtpumpkin on Wed October 07, 2009 6:09 PM User is offline
Well.
I'm a bit embarrassed to say, but it is a Generic Branded refurbished set. There are no markings on it. I just thought all the hose ends were standardized. It looks like most of the gage sets I've seen.
Edited: Wed October 07, 2009 at 6:28 PM by grtpumpkin
HVargas on Wed October 07, 2009 6:39 PM User is offlineView users profile
Pull one out and see what shape it is. These are cylindrical and are the only one's we have and they come in a 10-pack.
Contact: Arizona Mobile Air
Edited: Wed October 07, 2009 at 6:40 PM by HVargas
grtpumpkin on Wed October 07, 2009 8:21 PM User is offline
Thanks.
Not tapered, about 9.5mm outer diameter, abbout 3mm inside diameter, about 7mm long and green in color. The opposite ends of the blue and red hose are just green o rings. You would think when buying a refurbished unit it would at least have new seals. E-Bay is not always the best deal. Havn't used this thing yet so don't know how good it actually is.
Dougflas on Thu October 08, 2009 5:23 AM User is offline
In the meantime, turn them up side down and put them back into the hoses. If they are too short, put a small o-ring under them.
HVargas on Thu October 08, 2009 3:39 PM User is offlineView users profile
Ours are the same length, O.D. but the I.D. is closer to 5mm than 3mm. Yours look closer to 5mm well.
grtpumpkin on Thu October 08, 2009 10:57 PM User is offline
Those are the ones. How do I order them? I don't see them on the website store.
Cussboy on Thu October 08, 2009 11:20 PM User is offline
I also need some of those seals. My gauge manifold is Uniweld brand (old, originally R-12).
NickD on Fri October 09, 2009 6:17 AM User is offline
Anybody consider the accuracy of these gauges? +/- 2 psi on the low side can make a huge difference, not easy to do with a gauge that has a +/- 10 psi accuracy.
HVargas on Fri October 09, 2009 11:08 AM User is offlineView users profile
Mastercool 82010
