Newb AC question
nauree on Tue September 29, 2009 1:17 PM User is offline
Year: 1998
Make: GMC
Model: Serria
Engine Size: 5.7
Refrigerant Type: a134
Ambient Temp: 77
Pressure Low: ?
Pressure High: N/A
When I stick the gauge on the low side pressure without the truck running it reads like 80psi. When I turn the truck on with AC on max it will cycle from 10psi to 50psi and the compressor is going off and on every second. Is this normal for it to cycle psi? When it reaches 50psi the compressor will turn on and it drops to 10psi and the compressor will turn off. The psi then starts to go back up to around 50psi and the compressor will kick back on again.
GM Tech on Tue September 29, 2009 2:24 PM User is offline
you have about 20% of the necessary refrigerant in your system---the other 80% has leaked out. Find and fix your leak...then evac and recharge to spec. Most likely leak location is compressor belly on your truck. is it oily? Do a forum search for "belly leaker"
