Removing AC lines for repair
MikeC5 on Fri August 28, 2009 7:39 AM User is offlineView users profile
Year: 85
Make: Porsche
Model: 944
Engine Size: 2.5 L
Refrigerant Type: R-12
Country of Origin: Germany
O.K. so I've tried to remove the long AC lines that go from the evaporator to the compressor and drier with no luck. The routing is such that I don't think it can be done without removing the engine, some brake lines, etc. I'm thinking of maybe cutting the (hard) lines in a spot where I'd be able to splice them back again using a swage-lok or something like that. The line appears to be steel (and the ferrules). I'll check with a magnet this evening, but the braze-on replacement fittings I see appear to be for aluminum tubing only. Any suggestions? I hate like hell to put this system back together with 25 year old hoses...
MikeC5 on Fri August 28, 2009 1:16 PM User is offlineView users profile
I see it may not be a bad idea to use a filter on the high side as a splice. Are there fittings available to do a splice on the low side fitting (larger diameter tube)?
