how much oil do I add
pitbull1 on Tue August 25, 2009 12:58 PM User is offline
How much oil do I add after resealing this v-5..I appreciate the help chick and gmtech..96 camaro 3800 engine
NickD on Tue August 25, 2009 1:40 PM User is offline
A very common question with the only correct answer being exactly as much as you lost. Course, that is assuming it was correct in the first place.
If you really want to be correct, would replace the accumulator, flush out the rest and add precisely what your manual tells you to. Anything else is a guess.
GM Tech on Tue August 25, 2009 2:10 PM User is offline
3 ounces in the crankcase- through the oil drain bolt
