gmtech..coil removal
pitbull1 on Sat August 22, 2009 4:23 PM User is offline
Thanks for the correction on the previous posting..How do you get the coil off this v-5.Is that snap ring inside holding it..thanks
mk378 on Sat August 22, 2009 4:42 PM User is offline
Yes the snap ring holds the coil on, but I didn't think you need to remove it to do a reseal job.
Chick on Sat August 22, 2009 5:10 PM User is offlineView users profile
V5's have the coil pressed on, didn't read the other post, but the little snap ring might be the front seal you're looking at?? Denso's use a snap ring, and some others, but GM is always a press fit, use opposing screw drivers to wiggle them off...
pitbull1 on Sat August 22, 2009 5:12 PM User is offline
All except for one bolt would clear,so yeah.had to remove the coil..but I figured it out..All I see after bumping the front half of this comp. off is one belly seal..Is that all I need to change on my belly leak..thanks
Chick on Sat August 22, 2009 5:16 PM User is offlineView users profile
V5's have "two" case O rings, same size.. One in the front and one in the rear, both on that middle section.. . I'll have to get a pic up of that Monday..Don't forget if you are changing them you will need to change the shaft seal also..
Edited: Sat August 22, 2009 at 5:16 PM by Chick
