Extra Nipple on new compressor
glembke on Fri August 14, 2009 1:02 PM User is offline
Year: 1984
Make: Buick
Model: Skylark
Engine Size: V6
Ambient Temp: 85
Pressure Low: 0
Pressure High: 0
I just got a 134a conversion compressor from A/C kits. The old compressor had a red nipple on the back of it. One of the lead from the connector connects to the clutch. Can I just bypass the connector and tie them together?
TRB on Fri August 14, 2009 1:06 PM User is offlineView users profile
What the item number in question?
mk378 on Fri August 14, 2009 2:05 PM User is offline
Sounds like a high pressure switch. Take the switch out of the old compressor and put it in the new one, replacing the plug that's there now. If you bypass the switch, you risk blowing a hose or something should the pressure become abnormally high.
glembke on Fri August 14, 2009 3:42 PM User is offline
My bad... didn't see the snap ring under the grime on the old one and didn't look close enough to see it on the rebuilt one (it was under the paint). Thanks for the reply!
