Nylog and other questions
JW on Thu August 13, 2009 6:33 PM User is offline
Year: 1995
Make: Chevrolet
Model: Lumina
Engine Size: 3.1L
Refrigerant Type: R134A
Ambient Temp: 90
For those of you that use Nylog - should it be used on the flat sealing washers in addition to the o-rings?
Also, a compressor/accumulator/orifice tube replacement will be done. Should all o-rings be replaced while the system is open, or just the ones that are disturbed?
Thanks for your help.
Dougflas on Thu August 13, 2009 7:34 PM User is offline
My thoughts are if they don't leak, leave them alone. You don't want to butcher any fittings due to corrosion.
Chick on Thu August 13, 2009 7:42 PM User is offlineView users profile
Not on sealing washers, except the rubber part in the center won't hurt, only replace the O rings you disturb as long as the fitting don't appear to be leaking....Just my opinion..
