Civic 98 expansion valve replacement
go100map on Wed August 05, 2009 1:51 AM User is offline
Year: 98
Make: Honda
Model: civic
Engine Size: 1.6
When I pull the evaporator out from my car , I realize it is hard to get the expansion valve out , the service manual says that I need two wrench to do the job.
anyone knows how to fix the expansion valve with a wrench ?
HECAT on Wed August 05, 2009 6:55 AM User is offline
Without looking up the specifics on this model; the Honda's I am familiar with have a block type TXV sandwiched between the manifold of the evap and a short rigid line assembly that feeds to the firewall where the underhood lines connect. This assembly can be retained with a thru bolt and nut, and thus the two wrench instruction. Hold with one, turn with the other.
