Cleaning Condensor
99Yukon on Tue August 04, 2009 4:02 PM User is offlineView users profile
Year: 99
Make: GMC
Model: Yukon
Engine Size: 5.7
I was attempting to flush out my condenser, but air will only flow one way, is that normal?
TRB on Tue August 04, 2009 4:56 PM User is offlineView users profile
For the most part you should be able to move air in both directions. Odd you would have a restriction in one direction only!
iceman2555 on Tue August 04, 2009 7:55 PM User is offlineView users profile
The air flow method of 'flushing' a condenser is not a sound method to clean the unit. A liquid flush is necessary to properly clean the unit. Air WILL NOT remove debris fields from the inner tube surfaces of the condenser.
Had a tech call last week on a GM type condenser that would not flow air in both directions. The 'tech' seemed to think this was an accepted method to 'test' a condenser...yeah..right!!
This unit actually had the RD as an attachment to the condenser. The blockage was in the RD.
This condenser should flow air in both directions. Insure that the orifice tube is removed from the condenser outlet. This small orifice could be the cause of the 'one way' flow. Also when re installing this unit..keep in mind that the condenser can be installed upside down or the inlet/outlet hoses connected incorrectly.
cc61 on Wed August 05, 2009 7:13 AM User is offline
are you trying to blow thru the orifice tube???
cc61 on Wed August 05, 2009 7:14 AM User is offline
sorry iceman I just seen where you said that about the orifice too my bad...
99Yukon on Wed August 05, 2009 11:34 AM User is offlineView users profile
I removed the condenser from the vehicle, and removed the orfice tube out of the line so that definitely was'nt a factor. Thank You for the responses.
