Evacuated the A/C to fix a leak and then refilled it, do I had to replace the dryer??
HamadUP on Mon August 03, 2009 4:26 AM User is offline
Year: 1971
Make: Chevy
Model: Corvette
Engine Size: 454
Ambient Temp: 90
Pressure Low: 60
Pressure High: 230
Country of Origin: Qatar
I had a small leak in my newly built A/C, I had to evacuate and then replace some O-rings and then pull vacuum again and re-fill with fresh R134a, the system was exposed to the atmosphere for less than 30 min. , do I have to replace the dryer in that case? .. what's the maximum period of time the dryer would be let exposed to atmosphere and still be usable?
The A/C now is working fine, but I'm alittle worried about re-using the same dryer again!
Cussboy on Mon August 03, 2009 8:56 AM User is offline
Don't worry. It's not like moist air was being pumped through the accumulator.
I replaced the manifold hose assembly on my dual-air R134a '94 Suburban in January, and didn't replace the accumulator. Mine was "open" 1/2 to one hour.
Edited: Mon August 03, 2009 at 8:58 AM by Cussboy
HamadUP on Mon August 03, 2009 11:16 AM User is offline
But mine is the old TXV and dryer system, not the accumulator with the orifice one. Is that making any difference?
Cussboy on Mon August 03, 2009 2:36 PM User is offline
No. You'll be fine. You say it's working fine currently, don't mess with it.
