GM Clutch Adjustment (again)
wm8728 on Wed July 29, 2009 12:37 PM User is offline
Year: 1994
Make: Chevy
Model: Suburban
Engine Size: 5.7L
Refrigerant Type: R-134a
re: GM compressor clutch adjustment
If I understand correctly, the nut on the hub may have come loose (or there is another reason for a wide gap), thus my gap is now about .125". As a result, it only engages infrequently, but engages every time when tapped with a wooden rod. Do I simply tighten the hub nut to shore up the hub and close the gap, or do I need the special tool to remove, look for shims, maybe reshim, and retighten ?
Biker Bil
GM Tech on Wed July 29, 2009 12:53 PM User is offline
No shims in this press fit design- "borrow" clutch tool from Autozone- remove clutch nut- apoply tool- adjust clutch to .020" see link below-
Note: the nut is only there for looks- keeps dirt out of threads- will NOT adjust clutch for you- it bottoms on end of shaft, not clutch driver.-- it was discontinued on later models.....
clutch tool from Autozone link
