SD7 and evaporator freezing?
FishFinger on Wed July 22, 2009 2:19 PM User is offline
Am I right in thinking that variable-displacement compressors like the SD7V16 I'll be using for a custom install don't normally require a temperature switch on the evaporator to prevent freezing?
GM Tech on Wed July 22, 2009 3:13 PM User is offline
That IS the advantage of variable stroke compressors---but they are usually calibrated in a wind tunnel to their specific application...so as to optimize cooling without risking freeze-up....
