2002 excursion Ac PLEASE HELP
Bradmperry on Sat July 18, 2009 5:05 PM User is offline
Year: 2002
Make: ford
Model: excursion
Engine Size: 7.3
Ambient Temp: 95-98
Pressure Low: 35
Pressure High: 150
repair shop changed compressor, condenser, accumulator,orifice tube, blower motor, and eatc contol unit. They also added an electric auxillery fan, checked blend door and recirc door. The compressor and lines are cold and full of condensation yet the interior vent temp is in the 70's. When it is late at night and cool out(80's) the interior vent temp gets down to the low 60's but during the day it will not cool. Thanks in advance for any help.
fonebone on Sat July 18, 2009 5:50 PM User is offline
Those pressures at that ambient temps sure look like you are undercharged. Did you take those readings, or are they the readings the shop had? Look around this site at the FAQs, and note the pressures of R-134 at different temps. You should be higher. (Sure looks like the typical Ford blend door problem raising those vent temps,though)
Chick on Sat July 18, 2009 6:03 PM User is offlineView users profile
Low charge make sure they didn't fill it for a single air unit and you have dual air, or if they did it right you have a leak.. And they did fill it by weight I hope...
Bradmperry on Sat July 18, 2009 6:12 PM User is offline
These were the readings at the shop, but my buddy checked it this morning and they are same. the shop said the 134a was put in by weight.
Bradmperry on Sat July 18, 2009 6:35 PM User is offline
Should the compressor be cold and wet like it is or should it be warm to touch?
TRB on Sat July 18, 2009 9:22 PM User is offlineView users profile
Depends where you are getting to temp from. Compressor body will be hot while the suction line running into the compressor with be cold.
