fan works sometimes
fonebone on Sat July 18, 2009 1:14 AM User is offline
Year: 1997
Make: buick
Model: lesabre
Engine Size: 3800
Refrigerant Type: 134
Ambient Temp: n/a
Pressure Low: n/a
Pressure High: n/a
A Buick owner says her fan speeds do not come on right away when using A/C, but takes several minutes before it kicks in. It is not a ATC unit, but manual control. Tried moving a few harness connectors, but no go. Couldn't spend much time on it. Any ideas what it could be? Thanks
Chick on Sat July 18, 2009 7:48 AM User is offlineView users profile
Dead spot in the blower motor? bad resistor?
GM Tech on Sat July 18, 2009 8:35 AM User is offline
Next time it is slow to come on---tap (or whaaappp, or kick) the blower motor---if it comes on-- time for a new blower motor...also check connections for hot spots while you're in there...
NickD on Sat July 18, 2009 9:43 AM User is offline
Fan or blower motor, infers the blower motor where the fan is related to the engine. Seen cooked connectors at the resistor block, and if the vehicle has more than 60K on it, can certainly suspect the blower motor itself. Too bad you can't see the brushes to determine if they are at the end of there live. Can certainly spin the blower wheel, that cold rolled steel shaft sure loves to rust and bind. Can't even remove the blower wheel without breaking, plastic and gets very brittle with age. Blower motor switch itself is bare copper with harden grease on it and green contacts. Those can be repaired if that high blower motor current didn't warp the plastic yet. But if it's bad, can't even replace the switch, takes a very special tool like a phillips screwdriver to remove two screws, so they make you buy the entire climate control panel.
Typically GM uses a high speed relay where the switch only has to energized the coil, but does offer a different path to the motor, but can play with the switch to see if it's erratic. The fuse and connectors can also be corroded, but leave tell-tale signs of burning due to the high blower motor currents.
fonebone on Sat July 18, 2009 5:40 PM User is offline
Thanks, all; I'll try kicking, tapping, and whaaaping that blower motor first
fonebone on Sat July 25, 2009 8:02 PM User is offline
Hey GMTech; One light tap on the blower motor and it roared back to life! Also checked the connector, and it seemed secure. Showed the lady how to do it and she said she had a hammer in her trunk. She said it was a lot cheaper than having a garage take her to the cleaners. Got a good laugh on that
GM Tech on Sat July 25, 2009 8:44 PM User is offline
I had a woman kick hers for nearly a year until she finally gave up and let me replace it.....sure is an easy diagnosis when they do the work for you....
fonebone on Sun July 26, 2009 2:59 AM User is offline
By the way, not that I feel THAT ambitious, but how much work is it to replace that blower motor?
GM Tech on Sun July 26, 2009 7:51 AM User is offline
Piece of Cake-- maybe 20 miutes- tops
NickD on Sun July 26, 2009 9:29 AM User is offline
When these were six bucks a piece, MSRP, had screws on them, could be easily taken apart and a set of brushes were available for around 25 cents. Armature shaft was always rusty and the wick bone dry, that could be cleaned and oiled. Today, a second mortgage, and strictly a throwaway item, welded and the blower wheel, now brittle and hot stamped on.
But I still rip them apart and save the magnets, have a steel cabinet next to my work bench they cling to. Handing to slide a screwdriver tip several times to magnetized the end of it so it will hold a screw, at least you are getting some use out of it. Rest goes in the trashcan.
