97 Chevy C/K Issue with Accumulator Fitting
buddhalite on Sat July 04, 2009 1:19 PM User is offline
Year: 1997
Make: Chevy
Model: CK Pickup
Engine Size: 5.7L
Refrigerant Type: 134A
Ambient Temp: 100
Pressure Low: -
Pressure High: -
Hello all,
I have come once again begging to the experts.....
I have a friends 1997 Chevy Pickup in my driveway - the thing had a belly leak and I replaced the compressor, accum, orifice tubes and the clutch switch (found that out when trying to charge....)
Well, the last guy that worked on this thing buggered up the connection to the accum from the evap side. I got it busted loose - but the threads and such are all rusty. I cleaned it as best as I could.
Flushed, vac'd (held at 25 for 3 hours) and charged. Started losing refrigerant after about 2 minutes of running.
Turns out - the o-ring gave way on the evap to accum connection. ARRGH!
Trying to do this on the cheap - the threads are just rusted up and won't compress the fitting to squeeze the O-ring. Any suggestions? I really don't want to have to pull the evap and get a new fitting crimped and such....
Thanks for all your help over the years.....
TRB on Sat July 04, 2009 2:16 PM User is offlineView users profile
If yo can't get it to seal with a new o-ring and Nylog replace the core or have someone weld a new fitting on the end.
Cussboy on Sat July 04, 2009 3:46 PM User is offline
Can Tim supply a slightly thicker O-ring?
TRB on Sat July 04, 2009 4:58 PM User is offlineView users profile
I'm sure we have a #12 captured o-ring around somewhere. Will it solve this issues maybe with some Nylog but there is only one way to know for sure.
zzljg on Sat July 04, 2009 7:29 PM User is offline
They make they chasing files,,they are square , come in different sizes and have a a diferent thread pattern on each end and side ,don't know if they have them for that size but might be able to come close or try a small 3 corner file ,,just takes some patience to get the threads cleaned up,,,might be worth a try,,Google it and take a look ,,,,
Good luck
buddhalite on Sun July 05, 2009 2:54 PM User is offline
Thanks for all the suggestions. Nylog didn't make it happen....tried to clean the threads with a wire brush - and the threads disappeared!
Oh well - on to the parts store for a new evaporator!
Thanks for all the suggestions - you guys are the best!
