2000 ram or dakota 4.7 liter pag 46 or 100
Wavecrazed on Thu July 02, 2009 6:52 PM User is offline
Year: 2000
Make: dodge
Model: 1500
We bought a new compressor from the supply house here and they gave us pag 100 oil. The compressor has a sticker that says pag 46 on it. What we use sirs.
tim
HVargas on Thu July 02, 2009 7:01 PM User is offlineView users profile
Use PAG 46 on it. A lot of places only carry PAG 100 because it's in between PAG 46 and PAG 150 and think you can use it in anything. Use what the compressor calls for.
Contact: Arizona Mobile Air
chris142 on Thu July 02, 2009 9:08 PM User is offline
Chrysler cars call for 46 and the trucks usually take 100. Either will be fine.
TRB on Thu July 02, 2009 9:13 PM User is offlineView users profile
SP20 = PAG100
iceman2555 on Fri July 03, 2009 8:33 AM User is offlineView users profile
The correct lube for this compressor (Sanden SD7h15) is PAG 100 (ISO68). It does matter which lube is used. The use of a 'lighter' viscosity lubricant may lead to excessive compressor noise and possible bearing failures.
Also notice that on the Sanden compressor there is a 15mm bolt in the case. This is the preferred location for adding lube to the compressor.
Another major component failure on this vehicle is the condenser, especially after a catastrophic compressor failures.
