Thermistor Vacuum (Micron) Gauge ?
daman on Tue June 30, 2009 4:58 PM User is offlineView users profile
Has anyone used one of these are they good to have anything i need to know about it,found a used one at a local tool sale today the guy is holding it for me, mine is a little older model looking but the same thing.
stock photo..
Edited: Tue June 30, 2009 at 5:01 PM by daman
daman on Tue June 30, 2009 7:02 PM User is offlineView users profile
Nobody has seen/used one??????
TRB on Tue June 30, 2009 8:09 PM User is offlineView users profile
We use these in our shop.
daman on Tue June 30, 2009 9:03 PM User is offlineView users profile
Thanks tim,any info at all on this unit? anyboby?
SpinRite on Tue June 30, 2009 9:54 PM User is offline
Is this it?
(I hope the thermistor came with it...)
TRB on Tue June 30, 2009 10:02 PM User is offlineView users profile
Mastercool also makes a nice unit also.
Mastercool 98061
daman on Wed July 01, 2009 9:40 AM User is offlineView users profile
Originally posted by: SpinRite
Is this it?
No, it looks just like the one in my pic above...
bohica2xo on Wed July 01, 2009 1:03 PM User is offline
Daman:
If it works at all, it will work fine. Likely the batteries are dead, and will no longer hold a charge after all these years. It should still run ok on 110v.
Assemble it, and try the calibration. The sensor can be cleaned with trichlor or alcohol.
If you can get it cheap & it works, great. You can buy a Supco unit for less than 150 bucks new, and Tim sells some as well. It depends on how cheap you can get that one, and how much you want cordless operation.
B.
daman on Wed July 01, 2009 2:32 PM User is offlineView users profile
Thanks,gotch ya he's asking under 50,sensor is good,do they go bad with time/use?.
bohica2xo on Thu July 02, 2009 3:37 AM User is offline
A thermistor is fairly rugged. They do not wear out, but can be damaged. Very strong solvents, or blasting high pressure air through the sensor can do it. Normal use will not "wear" anything.
A thermistor type gauge is basically a resistor under load. At atmospheric pressure, a fixed load on a resistor produces a known ammount of heat. When you remove the atmosphere, the heat no longer has a place to go. As the resistor heats up, the resistance changes. The change in resistance is extrapolated to read vacuum.
The calibration adjustment on your unit is to compensate for things like barometric pressure, ambient temperature.
Contamination with refrigeration or vacuum pump oils will cause a loss of accuracy. The oil transfers the heat from the resistor to the body of the sensor - even in a vacuum.
To clean the sensor, cap one end & pour a bit of solvent in. Hold your thumb over the opening & give it a shake. Pour the solvent out. Alcohol or trichlor work fine for this. R11 was great for cleaning thermistors...
B.
daman on Thu July 02, 2009 7:53 AM User is offlineView users profile
Thank you very much bohica2xo!!
