expansion valve help
mxz583 on Sun June 28, 2009 10:02 AM User is offline
Year: 1997
Make: chevy
Model: G1500 express van
Engine Size: 5.7
Ambient Temp: 85
Pressure Low: 32
Pressure High: 175
can someone tell me the what the difference is between these two expansion valves mostly superheat and ton and the effect it would have on the system
DescriptionValue
Capillary Tube Length16-1/2"
Equal Tube LengthInternal
Fitting TypeO-Ring
Includes(2) [24606] O-Rings
Inlet Fit#6 MIO
Inlet Thread5/8 - 18
Gaskets / O-Rings:(1)-[24606]
Outlet Fit#8 MIO
Outlet Thread3/4 - 16
Superheat4.5
Ton2
TypeTXV O-Ring Type
DescriptionValue
Capillary Tube Length20-1/2"
Fitting TypeO-Ring
Includes(1) [24606] Inlet O-Ring
Includes(1) [24608] Oulet O-Ring
Includes(1) 1/2" to 3/8" Adapter
Inlet Fit#6 MIO
Gaskets / O-Rings:(1)-[24608]; (1)-[24606]
Outlet Fit#8 MIO
Superheat8
Ton1.5
TypeTXV O-Ring Type
mxz583 on Sun June 28, 2009 8:07 PM User is offline
no one knows anything about expansion valve ?
brickmason on Sun June 28, 2009 8:57 PM User is offline
First of all, Im no expert but proper positioning of the exp. valve @ the evaporator is very crucial to the cooling of all exp. valve systems.
Plus proper positioning and wrapping the cappillary tube very well will also play a huge role in system performance, so rule all that out first before trying to modify your system!
At least thats how I understand your question!
Be patient and you will get a much more detailed answer to any and all of your questions from some of the other members!
brickmason
Just another brick in the wall
Had a little mule I fed him castor oil and every time he jumped the fence he fertilized the soil
mxz583 on Sun June 28, 2009 11:37 PM User is offline
i am not trying to modify my system i had to replace my compressor so i also replaced the rear expansion valve at the same time. now the rear ac has poor cooling and i think it my be because the the ac parts store gave me a different expansion valve that has different spec.
TRB on Mon June 29, 2009 12:22 AM User is offlineView users profile
Dual unit you should be using the 2 ton valve.
mxz583 on Mon June 29, 2009 6:49 AM User is offline
the one that was in there was rated at 1 1/2 ton. so what does that mean 2 ton or 1 1/2 ton is it the size of the opening or something else ? and what does superheat mean
TRB on Mon June 29, 2009 9:55 AM User is offlineView users profile
Superheat
