82 Chevy doesn't seem to be as cold as last year
ferg on Tue June 23, 2009 1:06 PM User is offline
Year: 1982
Make: Chevy
Model: C10 (Truck)
Engine Size: 350
Refrigerant Type: r134a
Ambient Temp: 97
Pressure Low: 60
Pressure High: 300
I don't have an actual temp reading at the vents but the system doesn't seem to be as cold as it should . Last year I replaced nearly every component including compressor, converted to r134a and used this forum to get everything dialed in. I don't recall now what type of oil or how much or how much r134a i used but I did everything as recomended on this board. It worked fine but now it's not quite as cold as I feel it should be. Any thoughts?
The pressures listed were with the truck at idle and the AC on max cold. When the truck is off the high side reading is 150 if that helps any.
Edited: Tue June 23, 2009 at 1:07 PM by ferg
HVargas on Tue June 23, 2009 1:20 PM User is offlineView users profile
Sounds like you might have a slight overcharge or some moisture in the system.
Contact: Arizona Mobile Air
Chick on Tue June 23, 2009 4:45 PM User is offlineView users profile
Leave the manifold hooked up and spray a mist of water on the condenser, if the pressures drop like a stone, you have air flow issues.. Might be time for a new fan clutch..
