neutronics
autowize on Mon June 22, 2009 8:32 AM User is offline
Hi, Can i reused the sensing plug for Neutronics sealant tester i was just experimenting with my new tool. Can it be reuse if there is no sealant in the system.
TRB on Mon June 22, 2009 10:25 AM User is offlineView users profile
You can use a cartridge until the point of a failure. So it is good to reuse the same one until it detects the presents of a sealer. At that point the cartridge with be worthless and need replacement.
autowize on Mon June 22, 2009 11:33 AM User is offline
Thank you TRB for your help
Peter_Coll on Tue June 23, 2009 9:19 AM User is offlineView users profile
Thanks Tim,
If you are using a used cartridge and you get a sealant indication, we strongly suggest testing with a new one to verify the result. Used cartridges can accumulate dried oil & dye and restrict the flow paths. If you are using a used one ant the test results are ok then you are good to go!
TRB on Tue June 23, 2009 12:47 PM User is offlineView users profile
That's interesting, would you say you can get a false reading with an older cartridge? I have the guys double check next time we get a positive test.
