GM 99 truck clutch won't engage when low side press sw jumped
roaniecowpony on Mon June 15, 2009 1:41 AM User is offline
Year: 99
Make: GMC
Model: 2500 truck
Engine Size: 6.0
Refrigerant Type: 134
Ambient Temp: 75F
I'm in the process of recharging after evacuating the system on a 99 GMC 2500 6.0 ltr. In the past, I simply filled the first half can or so and then started the engine and jumped the low pressure switch by disconnecting the plug and connecting the two contacts of the plug with a paperclip in the end of the connector. My recollection was that was all it took to engage the clutch. I do it now and na-da. The clutch never engages.
Could the clutch be out of adjustment? Any other things to check?
Many thanks
Dougflas on Mon June 15, 2009 3:20 AM User is offline
Try disconnecting the battery for a few minutes to reset the control head/computer
GM Tech on Mon June 15, 2009 10:04 AM User is offline
Those control heads don't set codes- like other GMs-- so unhooking battery probably won't help.
here is what I'd do.
Do you have 12v at compressor?
if yes, is air gap too wide? bump it while running.- then adjust it permanently.
other things to check- is HPCO connector plugged in on rear of compressor? does jumping it help?
does jumping a/c relay in underhood fuse/relay center help? does relay have a ground source from PCM?
is control head light for a/c on? (says a/c request is present)
you have already tried jumping LP cycling switch.....
roaniecowpony on Tue June 16, 2009 1:10 AM User is offline
It's been a yr or two since I've been on this site and I've forgotten all the names of the guys here. But, to answer your questions in reverse order:
Yes, I did try to jump the low pressure switch.
Yes, the control head light is on and switched to ask for A/C, recirc, cold, high blower.
The othes I'll have to work my way thru.
I 'm guesing clutch gap since this clutch has been on for over 70,000 miles. I'll do the check to dislodge it to get it to engage first and then check the gap. Do I have to remove the compressor from the truck to adjust the gap?
Chick on Tue June 16, 2009 7:47 AM User is offlineView users profile
No, most you'd have to do is remove the fan shroud out of the way, and of course the adjustment tools.. But with that many miles, it is looking like a clutch gap adjustment..Hope this helps.
Ps: Find and fix your leak, constantly topping the system off is NOT good..
