Vacuum Question
MHardee on Thu June 04, 2009 4:40 PM User is offline
Dumb question of the day...
Why does a vacuum pump not pull out the oil in a system? You take all of the steps to place oil in the compressor and Accumulator and then you apply vacuum. It seems that the oil would be pulled out as well?
Dumb Question #2..
I've seen plenty of folks add oil to the system after vacuum and leting the vacuum pull oil in.. Is this a bad practice?
Puzzled in Tennessee..
True Shade Tree
HVargas on Thu June 04, 2009 6:59 PM User is offlineView users profile
The reason it pulls just the water out of the system is because when the system is placed in a vacuum it boils the water out of the system and oil and removes it.
Contact: Arizona Mobile Air
fonebone on Sat June 06, 2009 12:52 AM User is offline
Hi MHardee; Adding oil that way is fine, if you have the special tool. If you know you needed oil when you had the system apart, then put it back together, then realized you forgot to add it, that is the way to do it. You add it when it's apart,and opened up, or when you assemble it and vacuum it out; either way. Better, of course when it's apart. (easier!)
Cussboy on Sat June 06, 2009 10:57 AM User is offline
Why does a vacuum pump not pull out the oil in a system? You take all of the steps to place oil in the compressor and Accumulator and then you apply vacuum. It seems that the oil would be pulled out as well?..
Water is volatile and refrigeration oil is not, it's chemistry and physics. Pulling a vacuum does at least four things:
(1) It pulls air out of the system.
(2) the vacuum (reduced pressure) enables water to boil (boil out of the system) at ambient temperatures; at atmospheric pressure 212*F is needed to boil water).
(3) If the vacuum holds steady after vacuum and shutting off valves, it can be an indicator of a leak (note "can").
(4) The resulting vacuum is an easy way to add the first charge of refrigerant.
