Does ACkits carry these?
pf24 on Mon June 01, 2009 12:54 AM User is offline
Year: 1997
Make: Pontiac
Model: Bonneville
Engine Size: 3800
Does ACkits.com carry replacement HS and LS service ports? I think mine are leaking, I believe they are the type that screws into the hose set
My harris replacement compressor doesn't work as good as the original did. Charge is correct and all fans are working good. My theory is the V5 control valve shipped with the replacement is a generic one and not the same as the original. Too bad I through out the original compressor. I need my AC to be colder.
Does ACkits carry replacement V5 control valves? I have a 1997 pontiac bonneville.
Thanks in advance.
Costa
TRB on Mon June 01, 2009 1:36 PM User is offlineView users profile
Control valves are available just need to know the color.
Low Side Primary Valve - 35-50033
High Side Primary Valve - 35-50021
pf24 on Mon June 01, 2009 3:11 PM User is offline
Thanks Tim, I don't know what color valve would of been on the origional compressor when the car was new. Any way to look it up?
I found the following info in the internet. Not sure how to interpret it. Which one will produce the lowest suction pressure? I think I want that one. Can you quote me on what ever color that is?
(Green - 37.5PSI) (Yellow - 40PSI) (Purple - 41.5PSI) (BLUE - 42PSI) (BROWN - 43PSI) (RED - 44 PSI) (ORANGE - 45PSI)
Also; the part 35-50033 has the discription ADAPTER FORD 13MM. Is this correct for my pontiac.
Thanks Again!!
TRB on Mon June 01, 2009 3:34 PM User is offlineView users profile
No it fits GM low side also.
Maybe GMtech and provide the color but I don;t have anything that references color versa application. I just pull it out and get the color code.
