1998 New Beetle Pressures/Specs
gferris on Thu May 28, 2009 1:48 PM User is offline
1998 New Beetle A/C problem
Static Pressure ~ 95 both high and low side
Compressor clutch engages and stays on, center bolt and nut rotate with clutch, no strange noise.
However - after running 5 mins with compressor on - low side pressure 85psi, high 125psi
Could this in any way be charge levels - i.e. is it worth dumping the system, putting a vac on, and then doing a recharge, to see what that does??
Or is this 100% indication of bad refrigerant control valve or something else bad inside compressor itself?
What is the charge spec (oz) for the 98 new beetle?
TRB on Thu May 28, 2009 2:12 PM User is offlineView users profile
24 ounces is the refrigerant capacity.
Of course some diagnostics should be done. But history tells us with this vehicle and posted pressures, you have a dead control valve in the compressor, which requires a replacement of the compressor.
gferris on Thu May 28, 2009 2:34 PM User is offline
That's about what I figured. The car itself isn't in great shape - definitely not worth the $1,100 approach. It might be worth the $350 DIY approach. Is it entirely dumb to even attempt to replace the refrigerant control valve ($70 ish with value and gaskets etc.) inside the compressor, or is that just asking for trouble having not tore one apart before and not having a clue what I will be getting into (but fairly mechanically competent)?
TRB on Thu May 28, 2009 3:08 PM User is offlineView users profile
They can be changed but you have to break down the compressor to the internals to do so.
