What tools are needed
Bulldog Steve on Sat May 23, 2009 2:47 PM User is offlineView users profile
Year: 1990
Make: Cheverolet
Model: Corvette
Engine Size: 5.7
Refrigerant Type: R-12
Hello,
Compressor 10PA20c
Need to replace my shaft seal.
What special tool's will i need to buy to install this seal.
I think the seal is a 21-34629.
Or would it be cheaper to box it up and send it to one of you experts to do it and i will be more than happy to pay.
Steve
TRB on Sat May 23, 2009 3:19 PM User is offlineView users profile
Clutch assembly needs to come off as well as the front of the compressor. Seal is push back inward for removal. So seal is needed and head gasket kit along with the clutch & shaft seal R & R tools.
robs on Sat May 23, 2009 3:44 PM User is offlineView users profile
Steve-
You'll first need the clutch hub installer and puller kit which is 91000-A. Then you'll need the seal service tool for your compressor, which is part 91320. I would high recommend also getting the the gasket kit to replace the ones you'll ned to replace when you open the compressor, 21-24649.
Bulldog Steve on Thu May 28, 2009 11:49 AM User is offlineView users profile
Thank you for the info. guys
Steve
