1990 GM Sierra Compressor Question
extramile on Mon May 18, 2009 11:05 AM User is offline
Year: 1990
Make: GMC
Model: Sierra
Engine Size: 305
Refrigerant Type: R-12
Country of Origin: Canada
Pressurized my system with nitrogen to find the leak and of course is was the O-rings on the back of the compressor, that was the easy part. On the back side of the compressor where the lines attach there is a plug that is broke off, it has a small tube sticking out of the compressor. What in the world is this plug for ??? This system has worked fine with this plug being broke off in the past 3 years just wondering now before I charge system system what it does. I believe the compressor is a Harrison, it is not the long size type but the shorter cylinderical type.
Chick on Mon May 18, 2009 11:30 AM User is offlineView users profile
you have an R4 compressor, and it's the pressure switch on the high side you are talking about.. some have two wires, yours has one..
GM Tech on Mon May 18, 2009 12:23 PM User is offline
On a 1990 vintage that is the switch that throws the system into recirc- when you are in next tio highest or highest fan setting, and next to lowest or lowest temp setting, and head pressure rises above 250 psi-- there is a TSB on it to just ground it permanently and forget the switch....which is what I do...I used to get all kinds of complaints that all of a sudden my fan goes into high high fen mode- then it goes down a level- then when in city traffic it goes up a level-- and what it actually is doing is going into recirc which gives folks the impression the fan speed has increased...We commonly called this the GM truck poor man's climate control......
extramile on Mon May 18, 2009 2:36 PM User is offline
How do I ground it then. The tiny pipe is sticking out of the compressor, forgive my stupidness as I'm sure the answer is simple.
GM Tech on Mon May 18, 2009 4:16 PM User is offline
You ground the wire that used to be attached to it- a single terminal plug in-- forget the switch in the compressor...you may have to hunt a little for that wire- can't remember the color---but it will be the only one not attached to anything- unless someone cut it off....
