'84 pickup R12 conversion
84silverado on Mon May 11, 2009 12:15 PM User is offline
Year: 1984
Make: chevy
Model: pickup
Engine Size: 305
Refrigerant Type: R12
Wanting to convert 1984 chevy pickup from R12 to R134a. What is required?
TRB on Mon May 11, 2009 3:41 PM User is offlineView users profile
Minimum requirements for converting a system to R134a.
If system has any refrigerant R12 left in the system it must be reclaimed by an approved recovery machine.
Accumulator/drier must be replaced with an R134a compatible replacement. Conversion fittings and label must be added to the system. Label should have the amount of R134a used and quantity and oil type listed. If vehicle is not equipped with a high pressure cut off switch it must be added. That is the required minimum! While complying with the EPA laws may not provide the best performance.
Flushing the system to remove the mineral oil and debris should also be done. R134a and mineral oil do not work well together so leaving it in the system with R134a is not recommended! O-rings should be replaced with either NBR or HNBR replacements. Adjustment of the pressure cycling switch may also be needed to achieve the best performance. In some cases an upgrade of the condenser may be required to achieve the original performance. In many cases the parallel flow condenser will not be available as a direct replacement. Using a universal parallel flow is an option. A new custom hose set would be needed for the different style fittings used on the various parallel flow condensers.
There are many different suggestions when charging a R12 system with R134a. System must be evacuated before starting the charging procedure. I suggest you start with about 70 percent of the original R12 charge and add an ounce at a time until vent and pressure readings reach the best available results. Remember it is easy to over charge a system with R134a so patience is important.
