2001 Nissan quest only rear evap cools
Alan Muller on Sat May 09, 2009 6:16 PM User is offlineView users profile
Year: 2001
Make: Nissan (Mercury)
Model: Quest
Engine Size: 3.4
Ambient Temp: 70s
This system has a rear evap with an expansion valve, and a front evap with a fixed orifice. I suppose it has a leak history because there's a dye tag on it.
The rear system cools and the front doesn't--or very little.
I've never worked on a system quite like this before. Is this behavior consistent with a low charge?
I dont' have much equipment for 134a so I'm trying to learn as much as possible before getting into it.
Thanks for any guidance.
Chick on Sat May 09, 2009 8:08 PM User is offlineView users profile
As you loose the charge, the rear will cool longer than the front. Have the system leak checked, find and fix the leak, pull the front O tube and check it for debris.. If it's clogged, it will also lose cooling in the front..
UV leak detection equipment
