performance compressor versus stock? whats the diff
pomai on Fri May 08, 2009 12:01 PM User is offlineView users profile
Year: 88
Make: chevy
Model: camaro
Engine Size: 5.7
What's the difference between a performance and a stock AC compressor.
I am installing a supercharger into my 88 K5 Blazer and needed to move the AC compressor from the driver to the passenger side. So I purchased a passenger side serpentine bracket #10055800 from a 88-92 camaro so I can accomplish this.
can I install a sanden compressor using this bracket. I've been told that this compressor is much better then GM's. is this true?
or should I just go with the GM type compressor.
Thank you,
Ed
GM Tech on Fri May 08, 2009 12:18 PM User is offline
Both those brackets (Blazer and Camaro) used an R-4 mounted compressor- A Sanden would take a special bracket- there are probably adapters out there--others should know...
