Bad condenser - best practices question
knkreb on Sun April 26, 2009 9:35 PM User is offline
Year: 2001
Make: Pontiac
Model: Aztek
Well, the in-laws a/c in their car is not working. Found good size stone took out condenser and knocked a sizable hole in it. It has been that way throughout the winter.
So, here is the best practices question: system has been "open" to the atmosphere for x-amount of time, exposed to all sorts of elements. How best to clean up/dry out? Changing the accumulator/etc and good vacuum gonna cut it? Or will I have to pull the compressor too? (for dumping the oil and refill with fresh to hope to keep the system dry?)
Thoughts?
Thanks!
You must have all the clues for an accurate diagonsis.
Matt L on Sun April 26, 2009 9:57 PM User is offline
I would think that flushing it would be prudent. The factory oil is probably not end-capped and will react with moisture, which they do have in the system.
GM Tech on Sun April 26, 2009 10:19 PM User is offline
You'll get the new Receiver/Dehydrator (not accumulator) with the replacement condenser- if you buy from a reputable dealer...it mounts to the condenser..
TRB on Sun April 26, 2009 10:33 PM User is offlineView users profile
Tough call, PAG attracts moisture so if the system has been open to the point that the PAG could have absorbed a fair amount? It would be wise in my opinion to remove as much oil as possible. New drier is supplied with the condenser we offer.
GM Tech on Mon April 27, 2009 9:28 AM User is offline
Right photo of condenser- but it is upsidedown-and backwards- the "blank" in the mounting hole is always on passenger side bottom- and the R/D is on driver's side- with inlet manifold on the bottom....view is of engine side of condenser as shown....just needs turned 180.
Tim- May help folks identify their units- for a perfect match if you vertically rotate that puppy 180 degrees that image.....just a thought- seems like little things like this bother me-- must be a mindset.. the maker of that image had a choice of how to photograph it-- why not make it like it is mounted in the van?
TRB on Mon April 27, 2009 10:56 AM User is offlineView users profile
Better?
GM Tech on Mon April 27, 2009 11:13 AM User is offline
Actually- here is the proper view- you needed to rotate it 180...I mislead you on the backwards part....sorry
Edited: Mon April 27, 2009 at 11:16 AM by GM Tech
