AC parts terminology question
F250 on Sat April 25, 2009 8:43 PM User is offline
Is the "Head Pressure Switch", "High Pressure Cut-Out Switch", and "Refrigerant Contamination Switch" the same thing? My service manual shows them all in the same spot under the hood, but each manual/diagram I have calls it something different (one of the three above). The only ac switches I see on my truck are the "clutch cycling switch" located on the accumulator, and the the one on the ac line, which I believe is one of the names mentioned above. Just looking for clarification, thanks.
99 Ford F250 Superduty with oem AC
Chick on Sat April 25, 2009 9:14 PM User is offlineView users profile
Just different terms for the same high pressure switch..
GM Tech on Sat April 25, 2009 9:15 PM User is offline
And your truck is the Ford in your signature panel I assume.....yes sounds like all the same- if three wires to the "switch" then it is a pressure transducer--
