Year: 97
Make: Saturn
Model: SL2
Engine Size: 116
Refrigerant Type: R-134a
Ambient Temp: 80ú
Pressure Low: 30psi
Pressure High: 80psi
So I done everything correctly, following the vacuum/recharge process on here.
Went to fill the system, and no matter what, the high side wouldn't get above 80psi.
I changed the compressor out, and it got to exact same, 80psi.
I'm thinking my expansion valve might be bad...but how could that cause only 80psi?
Any suggestions before giving up and taking it ino the shop...?
P.S.- I've put about 30oz of refridgerant in it now. (2ý 12oz cans)
Specs call for 1ýlbs.
87 Corvette
75 Chevy PU
93 Saturn SC2
Edited: Thu April 23, 2009 at 10:35 PM by TIMSPEED
You have a bad service valve connection, or hose check valve. Try pushing down on the high side connector to see if it will depress the schrader valve properly.
With 80f ambient, you are not even reading a proper static pressure for 134a. Your high side gauge should show that much pressure even if the pump was junk.
B.
Got to love those rotary vane pumps-- do a search for some hints on trying to make them pump- search for saturn, rotary, vane among other tags....
Well, if you keep stuffing refrigerant into it it will get cold... once. When something finally lets go, it will get very cold for a short period of time.
Get a real high side pressure reading and get back to us. At 80f ambient, the underhood refrigerant temp is likely well over 100f. Work with your couplers untill you get a reliable static reading before you blame anything else.
B.
I MIGHT not have exactly a full charge in it right now...
However, the odd thing is, I plugged my guages into my other saturn, which also doesn't have a working A/C, and the high side reading was right about the same (around 80psi).
Today, I'm going to plug it into my saturn that DOES have a working A/C (Yes, I have three saturn's) and if the high side STILL reads no higher than 80psi, I'm going to call it a bad guage or coupler somewhere (has to be the coupler)
87 Corvette
75 Chevy PU
93 Saturn SC2
