TXV a/c system questions
cejay825 on Mon April 20, 2009 10:59 PM User is offline
I'm building an after market 134 system for my non a/c GTO. I'm using a seltec comp,and an under dash evap unit w/TXV. Does this mean that the comp. will run continuously
when a/c is turned on ? If so, is this good or bad ? Is there a way to make this system cycle ? or maybe it doesn't need to??????????????
TRB on Mon April 20, 2009 11:13 PM User is offlineView users profile
Rotary or preset thermostat will take care of you cycling issues.
Rotary Thermostat
Preset Thermostat
cejay825 on Mon April 20, 2009 11:22 PM User is offline
thanks for the responce
So put this on the evap pipe, run the comp. power through it, and set the temp ?
TRB on Mon April 20, 2009 11:29 PM User is offlineView users profile
Best to insert the probe in the fins of the core itself.
cejay825 on Mon April 20, 2009 11:31 PM User is offline
no problem.
Do you think the t-stat is necessary ?
Edited: Mon April 20, 2009 at 11:32 PM by cejay825
TRB on Mon April 20, 2009 11:34 PM User is offlineView users profile
Absolutely!
cejay825 on Mon April 20, 2009 11:36 PM User is offline
sounds good to me!
I was just concerned with the comp. running all the time.
Thanks for the help!
TRB on Mon April 20, 2009 11:43 PM User is offlineView users profile
That's what the thermostat will cure! You have to cycle the compressor when the core gets to the point of freezing. Other wise it will just turn to a block of ice.
