compressor going bad?
hotstang on Sat April 18, 2009 6:07 PM User is offline
Year: 1993
Make: Ford
Model: F-150
Engine Size: 5.0
Refrigerant Type: R-12
My 93 F-150 with a 5.0 is starting to make a rattling noise in the compressor. It is the original compressor running R-12 and the system has never been opened in 225,000 miles. I checked the pressures and the high side is 80-100 depending on temp. When I change the compressor I would like to change to R-134. What do I need to replace beside the compressor or do I need to open the system to see what all has been contaminated before ordering parts? Which compressor would you suggest I buy to replace this?
Chick on Sat April 18, 2009 6:35 PM User is offlineView users profile
Pull the O tube and check it for debris, then flush the system of the mineral oil, change the O tube and accumulator. Use PAG 46 oil or BVA auto 100 ester oil. Ackits.com shows only the Sanden SD 709 compressors, but send an e-mail to the guys at ackits.com as Tim put up a post for new FS10's made by sanden which should work great for you. The condition of the O tube will tell us more of what needs to be doen, or maybe just the parts swap and flush.. Let us know what you find.. Hope this helps.
Chick on Sat April 18, 2009 6:56 PM User is offlineView users profile
Here is a link to new FS 10's if you have factory air. Dealer air requires the SD sanden.. I would also consider using R12 since it served you well for 225,000 miles.. Just a thought, it's still available...
