HOT ON THE DRIVERS, COLD ON THE PASS SIDE
JLM07R6 on Thu April 09, 2009 9:28 PM User is offline
Year: 05'
Make: CHEVY
Model: EQUINOX
Engine Size: 4300
Refrigerant Type: FACTORY
Ambient Temp: 80 F.
WEIRD PROBLEM THERE IS COLD AIR COMING OUT OF THE PASSENGERS SIDE AND ABOUT 10 DEGREES WARMER COMING OUT OF THE DRIVERS SIDE( ALSO DOESN'T SEEM TO BLOW AS STRONG ). THE VEHICLE DOESN'T HAVE DUAL CLIMATE CONTROL. I SWITCHED THE A/C TO THE FEET AND YOU CAN HEAR THE DAMPER DOOR CHANGE BUT DOESN'T MAKE A DIFF. WHEN YOU SWITCH IT BACK.ANY HELP OR SUGGESTIONS WOULD GREATLY BE APPRECIATED . PLEASE RESPOND AT: ( [email protected] )
TRB on Thu April 09, 2009 9:37 PM User is offlineView users profile
Verify that the proper amount of refrigerant is in the system. Would not hurt to replace the cabin air filter also!
Chick on Thu April 09, 2009 9:53 PM User is offlineView users profile
That is an indication of low charge...The evap might be freezing up partially causing the blower to seem weak.. Hope this helps.. If you can get, and post the pressures would be a help.
