Is There A Way To Use These Cans?
oldsman on Fri April 03, 2009 9:54 PM User is offline
Refrigerant Type: R12
I have four 12oz cans of Dupont R12 with a threaded nipple on the top like the new 134 cans. In the past I've only used cans with the dome top along with my short connection hose. I'm at my wits end trying to figure out how I can use these cans. The thread size is just a little smaller than the 134 cans so I can't rig something up to use one of those. I don't want to invest in gauges and the whole 9 yards. I just want to add a can to my car when needed. Anyone remember if they made just the short connector hose like the ones used on the usual R12 cans? Anyone have one? Any suggestions would be greatly appreciated.
Chick on Fri April 03, 2009 9:56 PM User is offlineView users profile
Use a side can tap.., works very well..
Hope this helps.
Dougflas on Fri April 03, 2009 11:43 PM User is offline
Those cans may have been used for air horns for watercraft.
JJM on Sat April 04, 2009 2:11 AM User is offline
Well that's sure prescription for a TSR (Total System Replacement). I've seen plenty of needlessly burnt up systems due to repeated "topping off". If the system is losing refrigerant, it's losing oil too. And the same thing that would happen to your engine if you kept refueling and never adding the proper oil will happen to your A/C system.
If you're going to work on anything, you need the proper tools... that is if you want to do things right.
Joe
oldsman on Sun April 05, 2009 10:23 AM User is offline
Well, I've been keeping this 89 Buick going for the last 7 years by adding a can every other year or so and putting a little oil in the hose first. The car could go to the junk yard anytime and living in the northeast I only need air conditioning 3 months out of the year. Since I have the R12 cans I'd just like to figure out a way to use them without spending a lot of money. Thanks Chick for the tip on the side can tap. I never heard of it. I looked up a picture of one. I'm wondering if the hose I've been using will attach to it?
Dougflas on Sun April 05, 2009 11:14 AM User is offline
you can use a standard hose but need to have a depresser on both ends.
