Added a few more weld on connections
TRB on Mon March 16, 2009 6:01 PM User is offlineView users profile
These will work nicely instead of the barb style weld on fittings when using barrier hose.
Hose Fittings and Ferrules
Select item link for larger image and ability to add item to shopping cart.
Preferred usage with barrier style hose and bubble style crimping tool.
We have many more fittings available besides what is listed. Feel free to contact our staff for help with additional fittings.
WELD ON #6BL 3/8' TUBE ALUMINUM OD FIT
Fitting Size 3/8
Hose Size #6
Item # 35-B6601-A
WELD ON #8BL 1/2' TUBE ALUMINUM OD FIT
Fitting Size 1/2
Hose Size #8
Item # 35-B6602-A
WELD ON #10BL 5/8' TUBE ALUMINUM OD FIT
Fitting Size 5/8
Hose Size #10
Item # 35-B6603-A
WELD ON #12BL 3/4' TUBE ALUMINUM OD FIT
Fitting Size 3/4
Hose Size #12
Item # 35-B6604-A
#6 WELD-ON BEADLOCK STEM OD FIT
Fitting Material STEEL
Fitting Size 3/8
Hose Size #6
Item # 35-S6601
#8 WELD-ON BEADLOCK STEM OD FIT
Fitting Size 1/2
Hose Size #8
Item # 35-S6602
#10 WELD ON BEADLOCK STEM OD FIT
Fitting Size #10
Hose Size #10
Item # 35-S6603
#12 WELD ON BEADLOCK STEM OD FIT
Fitting Size #12
Hose Size #12
Item # 35-S6604
Aluminum Braze Rod
20 sticks
Item # 42-00110
Aluminum Braze Rod
10 sticks
Item # 42-00110-10
Edited: Mon March 16, 2009 at 6:02 PM by TRB
