Advice on O-Tube?
Minx on Fri March 06, 2009 3:07 PM User is offlineView users profile
Year: 1993
Make: Ford
Model: Explorer
Engine Size: V-6
Refrigerant Type: 134 converted
Hi, guys:
I'm going to open the system up this weekend to fix a leaky connection. (There's a drip at the spring-lock fitting where the high-pressure line enters the condenser.) On Chick's advice, I'm also going to examine the O-tube.
The NAPA guy said I have a red tube, but Chick thinks it's blue. If I find a red one in there, should I replace it with the red one?
FYI, this system was converted by someone else years ago. It has the more advanced stock condenser of the two supplied for this vehicle.
Chick on Fri March 06, 2009 5:50 PM User is offlineView users profile
As far as I can find, your explorer uses the Blue O tube and I would leave it at that.. Hope this helps.
Let us know what you find in there though...
TRB on Fri March 06, 2009 5:54 PM User is offlineView users profile
Blue is listed with multiple vendors.
Minx on Sun March 08, 2009 7:45 PM User is offlineView users profile
Thanks, guys.
Where's a quick reference on how much 134 this system needs?
Chick on Sun March 08, 2009 8:03 PM User is offlineView users profile
Here is NAPA's guide I would start at 28 ounces and work up if needed.. The hotter the day you do it the better though... Try for good cooling between 2.2 and 2.4 times ambient temp on the high side.. Same temp in and out of the evap, do it slowly outlet may be just slightly cooler, and you're fully charged.. Hope this helps.
Minx on Sun March 08, 2009 8:29 PM User is offlineView users profile
Thanks, Chick. I'll bookmark that.
