10P17C Shaft Seal Retaining Clip
Gary Harrison on Thu January 22, 2009 8:59 PM User is offline
Year: 1997
Make: Acura
Model: 2.5 TL
Engine Size: 2.5L
I purchased a new shaft seal kit for my 10P17C compressor from ackits.com. The kit contains expected seal, a new C-clip retaining ring, and a compressor body oring (don't plan to separate the body). When I inspected the existing seal, I expected to see the C-clip retaining the seal, however instead I see a retaining clip that appears to have 3 tabs that drop into the ring groove and 3 trailing centering tabs that remain in the compressor coil extension nose (?). Any tips on removing this clip. I'm thinking I'll just destructively pry it out w/ screwdriver, and replace w/ C-clip in the seal kit.
thanks
See you down the ROW.
TRB on Thu January 22, 2009 9:21 PM User is offlineView users profile
SHAFT SEAL
Removal
Remove clutch plate and pulley. Remove shim(s) from shaft. Remove clutch coil if necessary.
Remove felt and felt retainer (if equipped). See Fig. 1 . Place shaft key remover on shaft and
turn to remove key.
1.
Remove seal plate snap ring. Engage plate remover on seal plate, and pull up to remove seal
plate. Engage shaft seal remover/installer to shaft seal, and pull up to remove shaft seal from
front housing.
2.
Installation
Apply clean refrigerant oil to compressor housing bore. Lubricate shaft seal with refrigerant oil
and install in front housing. Lubricate seal plate and install in front housing.
1.
Install shaft key, snap ring, felt retainer and felt. With clutch plate installed, ensure air gap
between clutch plate and pulley is .016-.028" (.41-.71 mm). If air gap is incorrect, add or
remove shim(s) as necessary.
Gary Harrison on Fri January 23, 2009 8:25 AM User is offline
Thanks Tim.
What I saw was the felt ring retainer. I removed this and found nothing beneath the felt ring. No C-clip or shaft key that I can see. I think the end of the compressor must need to be removed to access the seal.
thanks
