Jeep Comanche air install
Gjeepm on Tue January 20, 2009 4:13 PM User is offline
Year: 1989
Make: Jeep
Model: Comanche
Engine Size: 4.0L
I've got a 89 Jeep Comanche project truck. The truck didn't come with AC originally but I sourced a complete factory Mopar AC kit for that year/ model. As is, this would be an R12 install but I want to convert it to R134 while installing it.
In addition to getting the high/ low fitting adapters for 134, I'm guessing I should seal all threading with the HFC sealer you sell. As for o-rings will the R12 ones work? Or are o-rings specific to FC application. Finally, the compressor oil I need to replace...but I don't remember with what type?
Is there any other items that need to be address in the R-12 kit to make the R-134 conversion successful? I'm going to let a professional shop charge the system...I just want to get all the pieces in place. Thanks!
TRB on Tue January 20, 2009 6:32 PM User is offlineView users profile
Barrier hoses would be suggested along with a parallel flow condenser. R134a adapters and HPCO switch are required. POE oil like the BVA Auto 100 is what I suggest.
Gjeepm on Tue January 20, 2009 6:44 PM User is offline
Thanks. The kit supplied a factory parallel flow condenser. As for the hoses, are you saying that R12 barrier hoses are different from the composition of R134 hoses?
TRB on Tue January 20, 2009 8:56 PM User is offlineView users profile
If the hose has a plastic inner sleeve its of barrier design. If not I would replace the hose with barrier hose or use R12.
Gjeepm on Wed January 21, 2009 12:00 PM User is offline
Thanks...Can ACkits make the necessary barrier hoses w/ fittings for my truck? What would you need/ who should I call?
TRB on Wed January 21, 2009 5:39 PM User is offlineView users profile
If you send us the old hose sets we can rebuild them using barrier hose.
Jack or Rob would be able to assist you with this request.
Edited: Wed January 21, 2009 at 5:39 PM by TRB
