engine hot a/c off
autowize on Mon January 19, 2009 12:22 PM User is offline
Year: 2008
Make: Gmc
Model: Acadia
Engine Size: 3.6 V6
Ambient Temp: 80
Country of Origin: Saint Lucia
Hi, Am having trouble with is GMC truck. It says on the dash board Engine hot A/c off. Where should I start looking?
mk378 on Mon January 19, 2009 1:12 PM User is offline
This doesn't have anything to do with the A/C. The computer has decided the engine is overheated, and disabled the A/C to reduce heat load under the hood. So check the engine cooling system. If the engine really isn't overheated, the coolant temperature sensor may be out of spec and needs to be replaced.
autowize on Tue January 20, 2009 1:17 AM User is offline
Where is the coolant sensor located ?
autowize on Tue January 20, 2009 8:23 AM User is offline
I will try another thermostat to see.
